what is the best audio bitrate for:
116.6 + or - 11.9
thanks.
okay, I'll bite...
- what kind of file are you talking about?
- what application are you using?
- what are you trying to do to the file?
- what do these numbers refer to?
fill us in? or should we guess?- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
i'm talking in an .avi with virtualdub and I get the following error:
VirtualDub has detected an improper VBR audio encoding source and will rewrite the audio header with standard CBR...creating up to 7326 ms of skew...decompress the audio stream to an uncompressed WAV and recompress with a constant bitrate encoder (bitrate 116.6 +- 11.9kbps).
once i save the wav, put it in with tmpgenc, i encode the mpg but the audio isn't properly matched up with the video: example: their mouths are moving, but theres no sound, and the sound comes after.
any idea what 2 do?
thx. -
Okay, I haven't had a problem like that with Virtualdub, but it looks like you are being told to re-sample the audio with a constant bitrate of 116.6 kbps, but there's a margin of plus or minus 11.9 kbps.
So somewhere between 104.7kbps and 128.5 kbps will be right...
where is your source coming from? what are you trying to do with it?- housepig
Housepig Records
out now:
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 08:02 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
