  1. Hi
    I've finally found the best conversion program - Canopus ProCoder
    I am burning the mpeg2 files with Instant CD/DVD 6.5
    But unfortunatlly Instant CD/DVD doesn't recognize those
    files (the files which procoder created, m2p extension)
    BTW I have to use Instant CD/DVD and not other burning software such as nero because I have Toshiba sd220e DVD player
    Help
    what can I do ?????
    Amir
  2. Ahn... Maybe it's a dumb idea, but... Try to rename your file to .mpg or .mpe and try it again... The filename just won't matter if the file was correctly encoded. Hehehe... =)
  3. It's not a dumb idea but I've tried that already
    It doesn't work !!!
    Please anyone HELP me!!!!!!
  4. Multiplex the m2p and the m1v file with TMPGEnc... Then open the generated mpeg file in Virtual Dub... Extract the audio to mp3... And try again... hehehehe
    Long way, but I don't have any other idea right now...
  5. I didn't understan a word from what you've just said
    anyway i changed the extension
    and this time it works !!!
    Not so dumb idea after all
    But the last time I changed it didn't work
    All I saw was black screen!
    but again this time it does work !!!
    I don't know.....
    Thanks anyway
