I've found that MyDVD will lock up after capturing is stopped when applying chapter points during capture. The "save" box comes up but will just sit there with the hourglass and not allow text input. I must then terminate the program losing everything including temp files. If I capture without chapter points, it works fine. Fortunately I also have VideoStudio6 and Vegas4 which are working perfectly. Anyone running into this issue?
