  1. i have a JVC XM-565 3-disc DVD changer. i've been trying to get vcds to play on it and everyone i burn will not read in the player. the video is in the right format to burn the VCD. i'm using easy cd creator 5 platinum and it burns the vcds without a problem but everytime i try to play them they won't. i looked for a hack for my player but there doesn't seem to be one. please help me! if there's anything i may be forgetting to do or add to my vcds please tell me. ANY HELP WILL BE GREATLY APPRECIATED! thank you.
  2. Banned
    Apr 2001
    Calgary, Canada
    starting with the obvious - does your dvd player even support vcd's? if it doesnt, your hooped.
    if it says it supports them, then come back and we can talk
  3. Member Dhruv's Avatar
    Aug 2001
    Australia
    do the vcd's play on your computer?
    I only dream in black & white...
    MSN: paschendale@gmail.com
  4. my dvd player DOES support VCDs and my computer plays the cd as a VCD. any other suggestions??
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    dfens: ONLY post in one forum.
  6. Your JVC XM-565 is not listed as having VCD support. Try using a CDRW or a different brand CDR
    Sep 2001
    Australia
    use the dvd compatability test to see if your DVD player supports CD-R, if not, find out what brands of CD-R work if any. hope i helped
