Reinstalling after a hard drive crash, Win XP and have all the patches installed but SVCD2DVDMPG+ keeps giving me:-
Common Language Runtime Debugging Services
Application has generated an exception that could not be handled.
Process id=0xdf0 (3568, Thread id=0xdf4 (3572)
Click OK to terminate the application
Click Cancel to Debug the application.
I've removed it and reinstalled it, manually added the latest updates and still the same problem !!
AnonymousGuest
Try downloading the program again as the latest package should not give you this.
AnonymousGuest
Uninstalled the original through control panel, downloaded the latest version and installed it along with my reg.key and still exactly the same problem.
It was running fine until the hard drive crash now with a fresh XP install and all the MS updates i'm getting this and its really got me scratching my head for a solution.. -
do you have the following directory:
Code:C:\WINDOWS\Microsoft.NET\Framework\v1.1.4322
AnonymousGuestplusC:\WINDOWS\Microsoft.NET\Framework\v1.1.4322
C:\WINDOWS\Microsoft.NET\Framework\v1.0.3705 -
email me & I'll do you a special build to see if we can get to the bottom of it.
Changing duration on generated media?
By solarblast in forum EditingReplies: 1Last Post: 21st Mar 2011, 21:28 -
Can one get the generated command line paramters from SUPER?
By Wakewatcher in forum Video ConversionReplies: 2Last Post: 1st Jan 2010, 23:50 -
Going from avi to flv, generated file is empty
By jearbear in forum ffmpegX general discussionReplies: 2Last Post: 15th Jun 2008, 17:05 -
whited frames on generated h264
By marcio.sfs in forum LinuxReplies: 4Last Post: 5th Jun 2007, 14:48 -
SVCD2DVD error on start up 'Application has generated an exception...'
By Turnstyle in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 16th May 2007, 03:53
