I would like to combine two short DVDs (ie: each about 3 min in length) into one DVD with a menu to distinguish between the two. I am OK with the menu side of the process, but what is the best way of combining both DVDs onto one? Do I need to covert them back to AVI, create one larger AVI file and then re-encode back to MPEG2 or is there a much simpler alternative? I assume there will be a quality loss with this method. I’m a newbie, so sorry if this has been dealt with elsewhere.
copy all the vobs from both disks to your hard drive and rename the second dvd vobs as a continuation of the first
example
vob1 from disk 1
vob2 from disk 1
vob3 from disk 2
vob4 from disk 2
then follow the guides on authoring vobs -- i understand dvdlab accepts vobs for authoring soyou may find that the easy way
you would prob want to make a new menu OR
have disk1 menu play first and at end of playing vobs for disk 1 have disk 2 menu play and redirect to the newly named vobs for that disk
anyway there are guides for this on the left an d in the guide section
Combining Mini-DVDs into 1 DVD
By Jinga in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2010, 12:06 -
TS combining
By vassock in forum Authoring (Blu-ray)Replies: 7Last Post: 17th Jul 2009, 23:12 -
Combining two DVDs
By avz10 in forum EditingReplies: 2Last Post: 5th Oct 2008, 11:33 -
Need a simple menu system after combining several small DVDs plese
By scp1973 in forum Authoring (DVD)Replies: 1Last Post: 1st Sep 2008, 12:14 -
Combining DVDs
By whoisquilty in forum MacReplies: 14Last Post: 17th Mar 2008, 09:01
