First, I believe is a problem caused by me with some stupid mistake that I made. I have been capturing TV to my computer via and ATI all in wonder radeon 7500. I have been doing lots of tweaking and testing between capturing to different file formats (AVI, MPG, MP2, etc...). I finally got the right format that was perfect for my needs.. MPEG-1, low resolution, low bit rate.
So i finally have these files, and I want to get them on DVD. I originally used the software that was bundled with my Pioneer A05 burner, which was Sonic MyDVD. I soon learned how pathetic of an app this was. I imported the video files into the GUI, and found that one of the 30 min., low bit-rate, low res files took more than half the disk space!
This could not be, so I tried different apps from Sonic and Ulead. Same result. I did notice a recording option in Sonic's app called "DVDit!" that allows me to record a special bit rate when burning to the disk. I put it on 1.5, the same bit rate at which my captured files are, and hit record. Nothing but errors. Every app I get the same result, every time.
What am I doing wrong?
My DVD only supports PCM audio. This eats up loads of disk space. You need to use an authoring app that will allow you to keep your audio at mp2 or convert to Ac3. Do a forum search for info on what authoring apps are suitable.
(FYI, for DVD, even with mpeg-1, the audio MUST be sampled at 48khz) -
I suggest that you use SVCD2DVDMPG+ to put your VCD's on a DVD.
All-In-One guide, VCD or SVCD to DVDR/W with SVCD2DVDMPG+
https://www.videohelp.com/forum/viewtopic.php?t=159399
https://www.videohelp.com/forum/viewforum.php?f=37
Video perimeter issues when burning to DVD
By cb678 in forum ffmpegX general discussionReplies: 6Last Post: 6th Dec 2011, 15:25 -
Issues Burning MKV to DVD
By link_417 in forum Authoring (DVD)Replies: 10Last Post: 18th Jun 2011, 15:07 -
DVD Burning Issues
By stonesfan71 in forum Newbie / General discussionsReplies: 5Last Post: 14th Dec 2010, 21:25 -
Burning DL DVD Issues (Nero 8, Sony Encore and Ashampoo 8)
By JJ - Tampa in forum Authoring (DVD)Replies: 3Last Post: 14th Jul 2008, 22:43 -
DVD burning issues..............
By marine89052 in forum DVD RippingReplies: 5Last Post: 2nd Apr 2008, 23:56
