I've been reading some of the posts about picture dimensions, etc., but it doesn't really help. My problem is as follows: my pictures go off the top of the screen leaving a long blank bar across the bottom. This applies to the title/menu screen as well. Any ideas?
Very strange...
I can tell you that this is definitely not normal (or common).
Perhaps you are having a strange PAL/NTSC incompatibility problem...
If you live in North America or Japan, you should create your VCDs using NTSC.
If you live anywhere else, you should use PAL.
Is this the problem?
Regards.
Michael Tam
w: Morsels of Evidence -
Well I am in North America and I tried NTSC. The strange thing is that I get the screwed up pictures I mentioned earlier when I use PAL, but when I use NTSC I get NOTHING! It's driving me nuts. The player says it's playing and I get the "PBC" display but no menu, no title and no pics! Any other ideas?
Funny Photo
By budwzr in forum Off topicReplies: 5Last Post: 7th Nov 2011, 08:01 -
Photo DVDs
By ingeborgdot in forum Authoring (DVD)Replies: 6Last Post: 30th Mar 2010, 13:06 -
photo tidkets
By nmroja in forum Off topicReplies: 2Last Post: 31st Jul 2008, 17:49 -
How to at photo's to a DVD??
By dreovic in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2007, 16:24 -
photo cd's
By backdrop001 in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2007, 18:02
