The avi file i have is 718488kb
cbr standard ntsc
non interlaced
1:1 vga
video movie
2 pass vbr
I have tmpge set at 1600 bit rate
at 480*480 resolution.
The movie should be approx 1 hour 15 minutes.
480*480 29.97fps / 44100Hz stereo / 254 min 04 sec
tmpge is telling me that it needs 3373.65mb =+/- 5 disks actually 463.4% or disk space.
how do i make it smaller.... thanks for the help for a newbie
I used to be on top of all this stuff.. get out of college for a few years and suddenly i am lost like my parents used to be![]()
Reduce the resolution, or reduce the bit rate (my suggestion).
Hello. -
How low can i go with the resolution and bit rate and still have decent quality. It seems like its going to take me forever to have my puter do the conversions on these, so i'd like to get some basic idea so i am not just shooting in the dark.
The computer i am using is a celeron 1.7 with 128 mb ddr ram. how long should it take to process an average sized (700 mb) avi file?
Scott -
You can go to 352 x 240 with acceptable video, depending what standards you are willing to accept. Also, a little trial and error never hurt. So encode a sample to a rewriteabl, and see how it looks to you. Repeat until you get the quality and size you want.
Since your movie is only 1 hour and 15 minutes, you should be able to get it on a SVCD with a little tweaking, but definitely get it on a standard VCD with no problems.Hello. -
Depends on what program and what settings. With my AMD 2000+ it takes about 4-5 hours in TMPGEnc in the one pass modes 10-11 in 2-pass mode.Originally Posted by afss
You could try converting your fram rate to 23.976 instead of 29.97 fps--
Will -
ok
thanks
I am attempting one at 1600kb/s with the lowere resolution and slower frame speed and it still is going to be 3-4 disks... oh well
Any other area to trim in?
Scott -
Try www.kvcd.net, look for the templates section.
Will
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Am totally confused with dvd film conversion.
By frenchman96 in forum Video ConversionReplies: 6Last Post: 10th Nov 2010, 09:38 -
confused with avi settings:
By modern saviour in forum Video ConversionReplies: 3Last Post: 4th Oct 2010, 14:52 -
Capturing video... confused about some of the settings
By Cyber Akuma in forum Capturing and VCRReplies: 2Last Post: 20th Aug 2009, 11:05 -
HD->SD Conversion - Settings Help!
By Russell_hq in forum Video ConversionReplies: 0Last Post: 20th May 2008, 08:33
