I encoded divx -> svcd System [video only], and muxed the audio track later, but I got a horrible sync problem...This has happened to me for the past 4 svcds I've tried encoding...I've read that a codec clash is usually the source of the problem but since I'm not encoding the sound along with the video, could this be the problem?...
The sound which I muxed was a ac3 -> wav -> mp2 file...
Thanks...
Found the answer to my problem, thought I'd post it in case anyone had similar problems:
I ran my divx vid in g-spot and noticed it was encoded 23.976 so I loaded the SuperVideoCD (NTSCFilm) template...When I tried the SuperVideoCD (NTSC) my vid and audio were in perfect sync..
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 10:10 -
Mux & sync audio from different sources
By RWANDREWS in forum AudioReplies: 1Last Post: 9th Jan 2009, 10:06 -
MUX Help (newbie)
By thisisjontheman in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2008, 08:52 -
capturing using different compters for A/V = mux drift/sync issues
By drstrust in forum Capturing and VCRReplies: 4Last Post: 17th Nov 2007, 08:13 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 05:42
