  1. Users of TV2000 XP
    How do you create SVCD from your captured file? I am not able to select even 480x480. Is it something wrong with my card?
    Regards
    Dominic
    Apr 2002
    The State of Frustration
    Is it just with TV2000, or can you capture in Virtual Dub at 480 x 480?
    Hello.
  3. Originally Posted by Tommyknocker
    I think it is something to do with the TV2000 Driver (supplied with the card). I am not able to use the other driver "btwin*" (Getting Blue screen of Death).
    Even Virtual Dub doesnt accept more than 320x240 (I tried custom format too). Getting Error 418: Unsupported Video Format.
    Thanks and Regards
    Dominic
    Apr 2002
    Have you downloaded the updated drivers? I do not know exactly what card you are using, but I have a WinTVGo, and it captures at 480 x 480 with no problems.
    Hello.
  5. Originally Posted by Tommyknocker
    I am using WinFast TV2000 XP Deluxe card. (http://www.leadtek.com.tw/multimedia/winfast_tv2000xp_deluxe_1.shtml). I dont see any updated driver on their website. I bought this card couple of weeks back. I am also waiting for the response for the Tech Support.
    REgards
    Dominic
  6. cap at 640x480 to any avi format, then encode and resize to svcd with tmpgenc.
    Perth, Australia
    iuVCR will allow you to set a custom capture resolution, might be worth trying, though it doesn't do mpeg1/2 captures so you'll have to convert it afterwards.
