has anyone used this windvd recorder for capturing and if so how would you rate it
thanx![]()
What we have here is failure to communicate!!
Guest
I've only used it for playing VCD's and other video files. For those it works great! It takes a bit to load but afterwards it's fine.
For my captures from cable TV I use WinDVD DVR. You can't get avi formats BUT the range of mpg's you get with it is large.
WinDVD 4 OEM - where to find it?
By mate in forum Software PlayingReplies: 4Last Post: 19th Apr 2010, 08:42 -
WinDVD 9 vs. PowerDVD 8?
By Vrex in forum Software PlayingReplies: 0Last Post: 7th Apr 2008, 22:54 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 20:57 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 22:19 -
WinDVD Creator 3 not recognizing .AVI
By wmrjw in forum Authoring (DVD)Replies: 4Last Post: 28th Jun 2007, 18:15
