im trying to add 2 movies to a dvd disk. it compiles just fine. converts them fine. but its putting them in the wrong order. im using DVD Auth and doing 10min chapters
Did you used SVCD2DVDMPG and then DVD Author to author?
it was error by the program, when it converted them from a bin, it names the files wrong
Can you elaborate?
the only way i can figure this out is that the files might not be named correct in the begining. somename.part 2.mpg will be for somename.part1.mpg.
Yf
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
