well with all the problems iv had over weekend... i think I might get it fixed tonight... anyway, i downloaded the trial version of both recordnow max and nero... the newest versions...
anyway, i know how to use nero.... but anyone have a quick run thru of how to use recordnow so I dont waist anymore disks???
i think recordnow is very similar to prassi.
open new job, then new data disc and add your VIDEO_TS and AUDIO_TS files.
set your speed and burn. -
YOU FORGOT TO TELL HIM
LOSE THE WIZARD (click on return to RECORD NOW)
Then what you said goes......... -
(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
PART 7a - BURN TO DVD WITH RECORDNOW MAX
If you do this part, do not do "Part 7b".
I recommend using RecordNow Max because I haven't noticed any problems with it while copying DVDs but you can use the recording software of your choice (I have noticed problems with Nero and some DVD players so I recommend using RecordNow if you can).
Startup RecordNow Max.
1) Select [Data].
2) Change [Volume Name].
3) Select [Add Files and Folders] and add ""VIDEO_TS" folder.
4) Select New Volume Under [Multisession].
5) Click the red circle.
After you use DVD Shrink, copy all the files to a folder named "VIDEO_TS", all capital letters. You might want to practice how to use Record Now Max with a RW DVD first. Anyway, hope this helps! Keep the faith, you're almost there!!!!!!!
8) 8) -
To Add to Burnmaster,
For Max Standalone Compatability under options, DVD, close the disc.
Enjoy
Anyone here use 3DS MAX?
By Rudyard in forum ComputerReplies: 5Last Post: 25th Jul 2012, 14:53 -
Max Mp4 player
By drrino in forum Portable VideoReplies: 1Last Post: 28th Feb 2012, 01:04 -
Xvid.Max conversion
By hawkeye48 in forum Video ConversionReplies: 0Last Post: 26th Jun 2011, 03:48 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2010, 00:35 -
MPEG-2 max bitrate
By Sjakko in forum EditingReplies: 16Last Post: 12th Jun 2009, 12:29
