How do I convert MPEG2 Resolution from 640x480 (or above) to 480x480?
My capture card (tv2000 XP) doesnt have an option to capture it in SVCD format.
Regards
Dominic
Use a program called TMPGEnc. Open the program and close the wizard if it opens. Load your video as input video, and name the output file. Select Load. A list of templates will pop up. Select the SVCD template, making sure your have the right format (NTSC or PAL). Select okay. Select Start. The finished product will a 480 x 480 MPEG-2 file the bears the name of your output filename.
Hello. -
Originally Posted by Tommyknocker--
Will -
Originally Posted by willy_annand
Regards
Dominic
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
FLV to DV-AVI with 640x480 resolution?
By kurganxy in forum Video ConversionReplies: 3Last Post: 4th Apr 2009, 11:22 -
How to convert 640x480 to 720x480 ?
By webstar in forum MacReplies: 3Last Post: 8th Jan 2008, 09:44 -
Do DVD resolution mpeg2 captures require to be encoded ?
By perfection in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2007, 17:08
