  1. i have two vcd concerts on cd-r, but it will not play in my dvd player..i have a pioneer dv-341..it plays my cd-r audio concerts..but i don't get no picture or no sound from the vcd..i didn't burn the cd..they are on sony cd-r..can anyone help me out
    thanx,
    -jeff
    bigwurock@yahoo.com
  2. Does your DVD player play anything else on the same type of media?
    Many DVD players are not designed to read CD-R/W media and do so erratically (i.e., they may be able to read one brand but not another).
    If your DVD player is designed to read CD-R/W media, then there is a chance that the VCDs were authored correctly. Can you play those VCDs on any other player or using a software DVD player on the PC?
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. You could try making a clone copy of the VCD to CD-RW (assuming the concert is standard vcd and less than 74mins) and trying it. I think Pioneer DV-341 permits CD-RW. If that doesn't work, try demuxing from the Sony CD to your PC, and re-muxing to mpg. Then burn as standard (using your usual burner software)
    I have had problems with a vcd that jumped and had terrible audio problems. I demuxed using TMPGEnc from VCD to HD and then re-muxed to form the MPG: then used VCGImagerGUI to make bin/cue (I use CDRWin to burn the umage file)
    and burnt to CD. The new VCD played fine.
