I am unable to get TV out display on TV from ATI all-in-wonder 128 rage pro on Windows Xp system. Using ATI Media Center 7.1
captuer/tv etc etc works well.
Tried all option. I could not.
Can any one light here.
Thanks.
I don't know how the ATI card works, but, on my Voodoo, when I set TV Out, it tells me it will resize to 800 X 600, and my SIS card doesn't even give me the option unless I am at 800 X 600 Res. Perhaps you have to set your res before it will allow it.
Also, does the ATI have both video in and video out connectors? Are they both connected? Or do you have to disconnect one and reconnect to the other? Or does it go both ways on the same connector?
If I have time, mebbe I'll go to ATI to see if I can make a more intelligent reply. -
do you have the ATI icon in you task bar? you may need to d/l the ATI control panel. I have an ATI AIW 128 PRO and didn't think of it till I saw your post...then I realized that I didn't have the Control Panel. To check, right click on the desktop, then choose properties. Under settings, choose "advanced". If you have an option for "displays" you are good to go...just click the "on" button on the TV display...(make sure you have the TV hooked up first via an rca video cable from the video out from the card to the video in on the TV...you should have no problems after that...let me know how it works
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 07:02 -
Clean uninstall of ATI AIW 9600
By justin81 in forum Capturing and VCRReplies: 3Last Post: 23rd Dec 2009, 11:41 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 14:25 -
ATI 7500 AIW capture problems
By saoneg in forum Capturing and VCRReplies: 8Last Post: 6th Mar 2008, 06:11 -
ATI AIW 9800 audio issue
By saggitarius in forum Capturing and VCRReplies: 1Last Post: 27th Jul 2007, 16:17
