OK so I downloaded this so called XVCD and I would like to burn it. The tutorial here says to use Nero and burn it as a VideoCD. The thing is I'm not sure if it's Mpeg1 or 2 for certain. The name states XVCD but I have no idea how to make sure for certain. Media player doesn't tell me that and so doesn't the file properties. The file is 40min long, 720x526, 25fps PAL and 750mb. Nero loaded it fine meaning that it could be mpeg1 but it didn't play in any player until I tried powerdvd which has a mpeg2 decoder, see my confusion? So how do you tell if it's Mpeg1 or 2?
since you already havve powerdvd, when the file is playing, right click and go to configuration. under the VIDEO tab (or something like that, i don't have the program open right now), it'll show you all the properties of the video (including mpg1 or mpg2).
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43 -
confused , newbie (more like overwhelmed)
By fordman37167 in forum Newbie / General discussionsReplies: 1Last Post: 28th Aug 2008, 22:44 -
Newbie confused. PC crashes/does wild when I attempt to record
By rob1974 in forum Capturing and VCRReplies: 3Last Post: 25th Aug 2007, 09:16 -
Confused about subtitles.
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2007, 02:38
