Results 1 to 9 of 9
    Dec 2002
    The Great Northwest
    Hi All,
    I just wonder if I am missing a button or something simple. I do not see a option for remove/delete post completely, [by author]. To me this would be a nice function, after a few too many Rum and cokes, or your chosen poison, this could come in extremely handy. I know it is always better to THINK before you post but as we can all see sometimes we do not always follow this great plan.
    We have all seen flames that perhaps could have just been removed by original poster before they got out of hand. Or simply to remove some incorrect advise or ill thought out question or answer. I just posted twice on the same thread by some mistake and it just made me wonder????? No Big.
    Dd
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
  2. Agreed.
    Sometimes you start a post... then, it takes on a life of it's own. People start talking about anything and the tread ends up being 30 pages of junk that has nothing to do with the original question.
    Don't give in to DVD2ONE, that leads to the dark side.
  3. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    I think in those situations (too many rum & cokes or double posting), you just have to edit the post and delete your message.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  4. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Editting and moederator closing are the only ways to accomplish this now. People were abusing the deleting function and it got switched off a few months back.
  5. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    I think the number of posts made would demonstrate the reliabilty of members to edit/delete their own posts.
    The facility not to delete your own posts when you can clear the original contents by editing seems rather silly to me.
    Without trying to sound elitist, that is not my intention, having made over 1000 posts I would like to be trusted to delete any posts I've made in error (although I can only remember a handful to be honest).
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  6. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    I think some of this gets into "mission creep" territory...
    what's easier for Baldrick - setting a bunch of custom permissions on the forum software, so someone with 1000+ posts can delete one or two of them, or just going in and editing the post and leaving a [deleted by author] in the thread?
    - housepig
    Housepig Records
    out now:
  7. Lost Will Hay's Avatar
    Oct 2002
    I have absolutely no idea what this means
    Yep, I completely agree.
    W.
  8. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    sorry, "mission creep" is a military term, it's when other tertiary concerns start to interfere with the prime objective.
    in straight terms - you are going to the hardware store to buy nails. So your wife asks you to run by the grocery store for 5 or 6 things, and your daughter needs you to drop her off at the library, and your son reminds you to gas up the car 'cause he needs it later... everything above and beyond the hardware store is mission creep.
    - housepig
    Housepig Records
    out now:
  9. As above. Unfortunately, deleting of posts (and even now editing) has been abused in the past.
    If you feel that you posted in haste, then you can always edit your post. If you are being flamed (and you deserved it), then a simple apology on the record is much better than deleting your post.
    Regards.
    Michael Tam
    w: Morsels of Evidence
