prob need quick sollution any 1 quickest way turning mpeg2 into dvd any 1 out there know the quickest way would realy help thanks
if your mpeg-2 is a dvd-compliant file, all you need to do is import it into some authoring software, set up menus & chapters (or not) and compile it as a dvd.
once you've compiled, burn the output files with your preferred burner.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
"best" is irrelevant, because what's "best" to me may not be for you.
I like DVD Lab - it's simple, yet deep, lots of advanced features in an easy to use app that's not expensive. www.mediachance.com
lot of people here like Maestro - it's pro level, serious authoring with a pro-level price tag (about $3,000 - 5,000 from eBay).
others like Sonic Solutions tools - DVDit, ReelDVD, etc. Or Ulead - DVD Workshop or DVD Movie Factory. Depends on what kind of money you want to spend, and what your needs are.
My suggestion, always, is download as many as you can get trial versions for, and try them out. There will be one that's easier to use, makes more sense to you, and feels beter than the others. That's the one you should use.- housepig
Housepig Records
out now:
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 09:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 21:00 -
Wireless prob?
By Immortal25 in forum ComputerReplies: 4Last Post: 3rd Jun 2009, 07:55 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 05:33 -
MPEG DV prob
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 24th Aug 2007, 17:01
