  1. I am trying to burn a very large ISO to a DVDR so it will can be used in a computer DVD-Rom drive. It is a program that will need to be installed off the disc. What option in Nero do I use to burn it. Everytime I tell Nero to burn Image, it will only let me use 700 MB, and acts like I have to put it onto a CD, even if I have my DVD burner choosen?
    Any suggestions?
    Thanks,
    papaholmz
  2. Sounds like you choose the wrong burner. You have CD and DVD burners on the same computer???
    If so, you should choose DVD burner as you desire from Recoder tap if I'm not wrong.
    Good luck
  3. I did choose the correct burner, but its still not working.
    Any more suggestions?
    Feb 2003
    use dvd decrypter to burn an iso image onto a dvd
  5. Thanks, it worked...... I was reluctant to try it becaue every DVD movie image I've ever burned with DVD Decrypter has not worked in my DVD player. For some reason, DVD Decrypter and my DVD player just don't get along (but I have no problem with Instant Copy or Nero)....... But it worked for software this time.
    Thanks,
    papaholmz
