Using Ulead DVD Workshop on Win 98, I authored 8 VCDs to 1 DVD which came out to about 3.3G. I played the VOBS using power DVD and on my Pioneer DV444 and I had really bad lip-sync problems. P155ED off or what?
I then authored the same file on a Win XP system and had no audio sync problems at all. Wierd or what??
Hope this helps anyone!
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Audio/Mic problem during filming, need a solution..
By sdsumike619 in forum AudioReplies: 16Last Post: 31st Jan 2012, 18:17 -
Console Video/Audio HD Capture Best Solution?
By Andrew Mills in forum Capturing and VCRReplies: 6Last Post: 2nd May 2011, 14:19 -
DVD - Mix Audio from two captures? What is the simplest solution?
By ChasePlace in forum Newbie / General discussionsReplies: 0Last Post: 29th Dec 2010, 11:26 -
Need a simple DVD -> MKV with 2+ audio solution
By herbapou in forum DVD RippingReplies: 4Last Post: 4th Mar 2009, 07:24
