  1. i am encoding avi file (Xvid) to mpeg2 than im getting grean screen results and its look like also that the picture is upside down...any help!?
    i try the guids at doom9 with no help...i usaly use ProCoder to encode
    but it is very slow....CCE is faster...
    Budapest, Hungary
    it seems you are having some codec problems..
    Do the files play fine in mediaplayer, before the conversion????
    If not then try ( re ) installing xvid and the latest divx.
    Also try the divx g400 filter but only if the above mentioned didn't solve your problem.
    The upside down and the green stuff strongly suggest that you are having problems with xvid.
    Anyone tired of his old DVD burner? Why put it into the trash? Contact me! :))))
  3. i have all the latest codecs i am seeing the movie fine in all type of player...when im converting with Procoder its fine even with Mainconcept...
