Hi,
I'm thinking about getting a DVD burner (the A05 or 06) and was wondering how tricky it is to do what I want. I have read a million guides, and am now very confused.
Here's what I'd like to do:
1. Take my DV cam, transfer the movie, add a menu etc. Easy Right? But I also want to store some audio and photos on the DVD and accesss them via the menu - as you get on some fancy DVDs from the store.
--->>> Can I do this too? Mixing movies, audio and having a photo gallery?
2. Next thing I want to do is take a bunch of vcd tv shows, and put them onto the dvd (I reckon you can get about 20 shows on 1 disc?)... and watch them without problem?
--->>> Am I right - VCD is easy with DVD? I know that converting other formats is tricky - but can I just dump my MPGs onto the DVD, burn and watch?
3. last, if I take a dl'd SVCD (2xbin and cue), extract the dat, rename to MPG, then I can burn them on a DVD and watch without problem right?
thanks for your help!
I've done this, what I did was import the pics into Vegas Video and set them to display for about 10 seconds each, and placed a simple crossfade transition between them. Then I added sound, and rendered it all as a dvd-compliant mpeg. Took about 10 minutes to do it.
Once I imported that into my authoring software, I just deopped chapter points at the beginning of each picture, so I could quickly get to one I wanted.
2. Next thing I want to do is take a bunch of vcd tv shows, and put them onto the dvd (I reckon you can get about 20 shows on 1 disc?)... and watch them without problem?- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
Quick easy way to convert DVD subs from 25fps to 23.976fps?
By nick1977 in forum SubtitleReplies: 19Last Post: 22nd Feb 2015, 17:36 -
A quick, easy, and accurate way to test MKV files?
By guht in forum Newbie / General discussionsReplies: 2Last Post: 1st Dec 2010, 10:25 -
Quick Hello :)
By Paul Iddon in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2010, 17:14 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 16:38 -
Quick and easy DVD9 to DVD5 video backup under Linux
By danboid in forum LinuxReplies: 7Last Post: 30th Sep 2007, 11:05
