I have attached a file to make it more easily understandable as to what I'm talking about. If you'll look at the dark pink area, you'll see them. They jump around in the video. Here are the specifics.
-It is a cartoon
-It happens even when I preview before capturing
-It only happens on certain colors, particularly those colors approaching red, such as orange.
-It is telecined, but reverse telecining doesn't remove it.
-It works fine when I connect the VCR directly to a TV
-It does NOT happen on the commercials, only the cartoon itself
-The tape was recorded in slp mode, meaning 6 hours of cartoons on it
Hmm, it doesn't look like my attachment made it. Anyway, the anomalies are almost like little checkerboard pattterns. If any of you have any suggestions, please let me know. I have a feeling since it is doing this on preview there's probably not much I can do about it.
I'm using huffy to capture. However, this happens even in preview mode. I have a viewing program called Quirix that monitors the capture port (viewing only) and it does it there too. I know that with some codecs, you can alter the incoming bitrate, but doesn't seem to be a way to do it with huffy. Hmm, I wonder if I altered something in my capture driver??
Oh, forgot to mention. This cartoon was recorded from the TV about 10 years ago. It was a Daffy Duck Thanksgiving special. It's one of the funniest things I've ever seen.
So, macrovision shouldn't be an issue.
Capturing From VHS Via VirtualDub Produce Strange Result
By max20d in forum Capturing and VCRReplies: 0Last Post: 8th Oct 2010, 23:55 -
VHS strange horizontal lines
By rekotc in forum Capturing and VCRReplies: 15Last Post: 21st Jun 2010, 16:24 -
Very strange VHS capturing problem..
By Veepa in forum Capturing and VCRReplies: 5Last Post: 3rd Apr 2010, 05:39 -
Very strange VHS to PC capture problem
By fredhoward in forum Capturing and VCRReplies: 45Last Post: 9th Feb 2010, 09:30 -
Strange sounding bass like noise when capturing from VHS. Help.
By Bricktop in forum Capturing and VCRReplies: 3Last Post: 9th Feb 2009, 10:21
