hi,,
just done a movie that was on a single vcd,
but the play back pauses every say 10-15
secondsb for about 500ms and the sound
comes in and out of sync,
just wondering would converting from ntsc
to pal cause this,,,
thanks,,
Results 1 to 9 of 9
How did you convert from NTSC to PAL?
What DVD player?
Is it a 100% compliant VCD?
I've had this happen, but I'll need more information to help you fix it.
- Gurm -
leaving besweet at default.think its ntsc to pal.
not sure if its a 100% compatiable vcd.how do
i check ?
Its an alba dvd-108.its even worse if i play it on
the pc. -
Heh. No what I meant is ... SVCD2DVDMPG+ doesn't do PAL->NTSC conversions. So how did you convert the file? Or are you just hoping that it'll play properly?
A lot of DVD players WILL play PAL SVCD's but will NOT play PAL SVCD-DVD's. I have found a way to make it work, but... it's not perfect.
Your best bet is to run the movie through TMPGEnc ahead of time, convert from PAL SVCD (480x536) to NTSC SVCD (480x480), and THEN use this program.
- Gurm -
yea.your right about besweet.my mistake.
i find that ntsc vcds dont play as smooth as
pal vcds.i think after running it through
svcd2dvdrmpg+.it makes the problem worse. -
Absolutely. Where are you located - in a predominantly PAL country?
My DVD player will play PAL VCD's, but they can tend to get a bit jerky if not perfectly encoded. And ... heaven forbid I convert them to DVD-SVCD's, because then I have to be VERY careful in order to get them to work.
Basically, this program is "faking out" your DVD player. Try not to throw the poor device any more curveballs than you have to.
If you live in a mostly PAL area, do yourself a favor, and use TMPGEnc or something to convert the NTSC movies to PAL before you use this program. You'll be glad. In a mostly NTSC area, do the opposite.
- Gurm -
My Dansai 852 plays both!
,,,,,,, :PSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Bite... me.
I am jealous of all with dual-mode DVD players.
- Gurm
Player pauses
By Daijard in forum Software PlayingReplies: 8Last Post: 9th Feb 2010, 20:53 -
how to record without pauses
By mehrlicht in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Apr 2009, 16:00 -
Pauses between the chapters during playback
By roblobster in forum Authoring (DVD)Replies: 8Last Post: 8th Feb 2008, 22:54 -
strange pauses between Chapters
By Adster in forum Authoring (DVD)Replies: 14Last Post: 22nd Sep 2007, 08:42 -
Video backups contain pauses
By dadbackup in forum DVD RippingReplies: 10Last Post: 15th May 2007, 15:13
