  1. Hi every1
    I capture to DV video.
    I see that DV audio is 48000Hz and VCD wich is my final goal is 44100Hz.
    I wonder what to do when editing in Pinnacle studio 8 or Premier 6.5.
    I think i will stick to DV when editing then the audio is still 48000Hz.
    After all is ready i want to convert in TMPGenc.
    Is there any problems known with 48000Hz to 44100Hz?
    I have made som VCD's this way without noticing any different like sync prob and so on.
    Any1 have a explanation on this 1?
    Thanks in advance!
  2. TMPGEnc will automatically convert from 48khz to 44.1khz if you select the VCD template.
  3. Yes but should i keep it 4800Hz while editing?
