hi,
if i play my dvd, which i created with ffmpegx, there are no sound. but with mplayerosx i can hear the sound on playing the vob files on dvd? whats wrong? any ideas?
cheers tom
i think so, after 2 trys and 3 days i removed the files. at the end there was one mpg file, 2 others with these extensions (mpv, mp2) and the vob stuff. at the beginning it created the stream.yuv and the audiodump.wav in my home drectory and the mpv file (no other one), it looks everything ok. on my second try while encoding i opened the wav file, i heard somesting. my first dvd works with sound, but the last one, with the same settings, has no sound (i tested with vlc, home dvd player and dvd player on macosx), only if load the vob files directly from the burned dvd with mplayerosx, i can hear something. is the sound for a dvd player outsite of the vob files or what are the different between a dvd player and mplayerosx?
sorry for my bad english. greatings from germany.
cheers tom[/b]
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
Remove Sound From Original DVD And Add My Own Sound To New DVD.
By MrJacobAngle in forum Authoring (DVD)Replies: 7Last Post: 30th Jun 2010, 14:38 -
editer shows 'no sound', mpg plays with sound
By oldvideote in forum EditingReplies: 3Last Post: 7th Jul 2007, 08:01 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
