Hello
I have a NTSC 16x9 DVD that I ripped (DVD Decrypter in movie only FILE mode) and I used Vobsub to RIP the subtitles.
Anyways ... I am using TMPGEnc to re-encode this film so that it will fit onto a single layer DVD recordable (the original is a DVD9 disc).
Now, I tried a sample encode where I used an AVISynth AVS script to resize the original 16x9 ratio to 4:3 and added the subs into the AVS script so they would "burn" into the image. I'm fine with this solution (as I would never want to watch this movie without the subs) but now I'm stuck with a 4:3 video instead of a 16x9 video.
So ...
Now I am thinking I will re-encode the movie at 16x9 and use an authoring program that supports (Vobsub?) subtitle files but ... very few authoring programs seem to support subs and a LONG time ago I played around with Maestro (wihch does support subs) and I very nearly had a nervous breakdown using that program.
So now the hunt is on for an authoring program that supports subtitle files and is easy-to-use
Does anyone have some suggestions? Also can I use the subs as they are or will have have to somehow convert them to another format? If I do have to convert what program should I use and how do I use it. Any links to guides would be helpfull but while I don't consider myself a newbie in the world of digital video I must admit I am a newbie when it comes to dealing with subtitles in the fashion I am seeking.
So any help would be greatly appreciated
- John "FulciLives" Coleman
P.S.
I own this DVD so if I need to RIP the subs again using a different program/method that is not a problem. However I'd rather not deal with the subtitle rippers that rip to some form of TXT file. Been there done that and it was not "fun" at all ... hehehe
Results 1 to 1 of 1
Does a simple AVCHD authoring program exist like DVD programs?
By Killer3737 in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Sep 2011, 12:16 -
Simple DVD Authoring
By DeathStalker77 in forum Authoring (DVD)Replies: 22Last Post: 26th May 2010, 02:40 -
Simple VOB authoring solutions
By kippard in forum Authoring (DVD)Replies: 5Last Post: 22nd Jul 2008, 09:27 -
Again on Simple DVD authoring
By asadfx in forum Newbie / General discussionsReplies: 1Last Post: 22nd Nov 2007, 08:22 -
Authoring a simple DVD
By asadfx in forum Newbie / General discussionsReplies: 2Last Post: 21st Nov 2007, 16:54
