Gspot tells me that the average bitrate for this AVI is 128kbps - I noticed that the average DVD bitrate is 4000-6000, and that at that point, a dvdr can hold 2 hours of video.
So, at 128kbps, will I A) Not lose any quality from this AVI and B) Be capable of storing a ridiculous amount of minutes on the dvdr?
It just doesn't seem to make sense in my head. The video is quite nice quality, and it seems unlikely that this will work as nicely as I figure it will. Is the avi bitrate able to be so much lower without sacrificing much quality just because of the codec? Will a 128kbps mpeg2 just look attrocious?
Originally Posted by Slug
B: Yup, you'll only find it difficult to store more minutes worth of video/audio on a DVDR if you use a high bitrate setting.
Not quite sure how it'll look. I'd say try to encode to that, and preview the mpeg2 on your computer, if it doesn't look totally horrible then burn it and have a look on your television.
Regards,I only dream in black & white...
MSN: paschendale@gmail.com -
AVI (DivX, XviD...) bit rate has no relation to what bit rate to use when you reencode it to mpeg2. Whenever you reencode, you'll get a copy that is more or less worse than the original. The higher the bit rate used, the closer to the original it will be (but never 100%).
/Mats -
At a guess, your AVI file that looks nice at 128k is probably a relatively low-resolution DivX (or some other MPEG4 variant like xvid), maybe even with a nonstandard framerate. If it's done correctly, MPEG4 encoding will almost always look better at lower bitrates than MPEG2. Your MPEG2 file will also have to follow standards on resolution and frame rate, which may be higher - even if it MPEG2 just as efficient it could still look terrible because you're trying to encode more data in to the same space.
Higher 2.0 AAC bitrate from Ripbot
By jntaylor63 in forum Blu-ray RippingReplies: 6Last Post: 3rd Nov 2012, 16:22 -
transcoding mp3 to higher bitrate questions
By spiritgumm in forum AudioReplies: 6Last Post: 28th May 2011, 16:46 -
MKV to AVI Video Bitrate Setting
By gonwk in forum Newbie / General discussionsReplies: 6Last Post: 8th Apr 2011, 19:31 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 21:33
