Hello All,
I hope this is the correct forum to post this.
I have some home made DVDs that were made with the Panasonic (I think) stand alone DVD Recorder. While the rudimentary menu works for it's purpose, I would like to remove it and add a decent menu (one that you can skip around to the different chapters and the like).
My question, what is the easiest way to remove this menu so that I can properly title and menu the DVD?
Thanks in advance for your help!
Best Regards,
Mike
you would need a dvd burner for your pc in order to do that. In a nutshell, rip the disc back to your pc and use the clips in another application--reburn
I have a DVD burner (Sony DRU500) and am familiar with copying discs and the like. I would like to keep the rest of the DVD intact and create a better menu system (probably using DVD-Lab).
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 01:50 -
DVD Reauthoring - Removing a menu
By xDarKnighTx in forum Authoring (DVD)Replies: 2Last Post: 2nd Jul 2010, 00:32 -
Removing the subtitle menu from a NORDIC dvd
By tooonami in forum Authoring (DVD)Replies: 7Last Post: 17th Feb 2010, 12:58 -
Removing Menu
By masterpkg in forum Authoring (DVD)Replies: 1Last Post: 27th Aug 2007, 04:05 -
Removing menu's music from DVD
By Turbo Sensonic in forum Authoring (DVD)Replies: 2Last Post: 4th Jul 2007, 22:22
