Why does TMPGEnc no convert or recognize the audio (sometimes) when I try to convert an avi file to a svcd mpeg file?
You should extract your audio to a wav file first and use that as your audio source, you'll have fewer problems that way. Goldwave is good for doing just that.
"Art is making something out of nothing and selling it." - Frank Zappa -
Yes,its ac3 audio.
The deal is I actually paid for my version of TMPGEnc and registered it.
I just assumed after shelling out money for software that it would work a little better at this basic function. -
Well, you need to install an AC3 codec on your sytem and then you'll be fine (look in the Tools section). No, TMPGEnc does not have codecs built-in. You need to install them depending on the type of file that you have. Goldwave will extract AC3 audio to wav.
Sound quality of Tmpgenc: Is it that bad?
By Banleno007 in forum Video ConversionReplies: 3Last Post: 15th Feb 2012, 21:10 -
TMPGEnc DVD Author-sound?
By Mållgan in forum Authoring (DVD)Replies: 2Last Post: 14th Apr 2009, 05:51 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 16:12 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 16:00 -
TMPGEnc Plus and AVI sound
By busdonic in forum Video ConversionReplies: 5Last Post: 22nd Jun 2007, 10:18
