i load the avi file in tmpgenc for "video source" but tmpgenc says itīs unsoportet;
i use the same file for "audio source" and it open.
using gspot:
video format codec 4cc xvid xvid
DirectShow Render
video codec XVID MPEG 4-VIDEO DECODER
video media MEDIASUBTYPE_YUY2
Just a hunch: Try to open the video in Virtual Dub, then see if it will frameserve to TMPGEnc.
Hello. -
I'm taking a guess here, but it sounds like you might have had Premeire in the mix somewhere. If so, here's a snippet from a forum question over at DVDHelp.us that might help.Originally Posted by pscf
Hope this helps!Your first problem is because of Adobe. It likes to do things its own way, and "doesn't play well with others."I have been using Ligos encoder and it generate too much artifacts on fast moving objects, so someone recommended the other built in encoder for Adobe, but that also generated too many artifacts. So I downloaded the TMPGEnc, but when I tried to convert my AVI files that were generated from Adobe 6.5 (Microsoft AVI export setting) TMPGEnc throws up an error saying that the file is either "can't open or is unsupported". Can anyone help? The AVI files are my cousin's wedding video, so I am trying to give her the best quality possilbe. I even try to use DVDit PE to do the encoding, it did get ride of the artifacts but the overall picture got fuzzy. This is my first time trying to burn a DVD, so I am very new at this.
You'll need to grab the Premiere plugin from the (DVDHelp.us) download area (It's in the Addon section) which will allow you to properly work with TMPGEnc. See the screenshot (on the download page) as well, as it should be helpful.
LisaEverything I know about video, I learned from:
www.DVDHelp.us -
alot of the reason why tmpgenc is sayiong its unsorported, is because its best to decompress it 1st
there are sooooo many posts about similar probs that a simple decompress fixes
decompress it 1st (i can send ya a decompressor small file)
then in vdub simply strip thae wav file
then in tmpgenc load the decompressed avi as yer video and the wav file as yer audio
any probs please ask me to send you a so easy guide to fix this
Can not open any file in TMPGEnc 4
By Soixante in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 09:56 -
can't open file in TMPGEnc
By windranger in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2009, 10:25 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
TMPGEnc 4.0 XPress Failed to open mts file
By jeremyotten in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 12:40 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 21:31
