ok, i have a small motion menu (oart of the movie in backgroun) that i want to edit...like adding an overlay picture or a button or anything just to change the look of it i dont want it like now...16:9 and thats it..
any ide or guides?
thanks
I guess it all depends on what format you have the menu in? A motion menu is simply using a small movie clip as the background. You can use any movie editing software to edit that movie, and then author your DVD with the output. I have used Adobe Premier for this task in the past, but any movie editing tool will work.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Slow-Motion editing program?
By Cipher5000 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 17th Nov 2011, 23:34 -
Editing and replacing a motion menu problem
By kpic in forum Authoring (DVD)Replies: 4Last Post: 5th Aug 2010, 17:11 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
Editing Motion DVD Menu
By gallardo in forum Authoring (DVD)Replies: 5Last Post: 6th Nov 2007, 21:12
