  1. Hi,
    I was wondering if it is possible to put two DVDs on one disc and still maintain menus.
  2. May be possible however the quality would be crap IMO.
  3. yes it is possible to ultimately get two dvd's onto one DVD-r, however, unlikely (as the earlier post said) to do it without it looking bad.
    What you can do is convert 2 dvd's to CVD using an app like dvd2SVCD and then take the resulting mpegs and author them with an app like movie factory 2
    May 2003
    Iceland
    I may suggest using a good DVD Authoring program which there seems to be a few good ones out there,
    myself I have been using TMPGEnc DVD Author, which I believe there is a link for in the tools section on the left
    Following is the way that I have been putting 2 movies on 1 DVD:
    1st: I process both movies with D21 113 movie only set at 2222mb and I only select the 6ch audio. [after processing with D21 each movie equals approx 2.17gig]
    2nd: I then start TMPGEnc DVD Author and import both movies each to there own track
    you can then create some really nice menu's and even change the chapter points
    [NOTE: With TMPGEnc DVD Author you can import VCD, SVCD or DVD and create a compliant DVD]
    3rd: I then open NERO and select DVD iso/udf mode and import the AUDIO_TS and VIDEO_TS
    folders created by TMPGEnc DVD Author and burn
    Hope this helps.......
