Results 1 to 16 of 16
    I ran my first test of svcd2dvdmpg+ today, very nice program!!
    I attempted to put 2 movies on 1 dvd. converted fine noi glitches I first tried to burn with ulead mf2 which wanted to convert the _dvd files so decided to burn with Nero using udf 1.02 which was a coaster=no disc
    so what am i doing wrong.. or is there a different program that i should be using to burn the dvd with?
    Great product I am amazed at the addons to the + version.. very impressive!!
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Why don't you let SVCD2DVDMPG+ author your DVD? If you have 2 movies then you can even have a menu!
  3. Banned
    May 2003
    Massachusetts
    And then burn it as a data DVD with either Stomp, CopyToDVD, or any other DVD burning (not authoring) proggy.
    - Gurm
  4. Or if you do want to author in another program try tmpgenc Author. That is what i use when a audio file is out of sync. And it works.
    ok sorry guys i've been up to the beach for a couple of days for some r/r!!
    after i finished converting it created a videots folder but it was empty.. i then moved teh _dvd files to the folder and burned with nero.. maybe i was wrong to do that.. I will try to use copy2one with data but I feeel like I am missing something.. it doesn't have to be authored does it?
    crissyboy i did choose to author with this prog
    I am wondering if i was right to move the _dvd.mpg files to the empty videots folder and then burning with Nero.. I am going to run it again to see if it is comes up empty again..
    let you know!!
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    hey whilst you were on the beach some of use were working. Do an update (followed by a reboot) - i think your issue has been resolved. Let us all know please.
    CB
    haha.. yea my days off are sunday monday.. back to routing bitchy ass customers tonight!!
    Listen I ran it again and all looks good except the final product is 1.5g the coaster in which I stupidly copied the _dvd.mpg to was 2.33.. is it normal for teh final to come out smaller??
    I guess i'll burn and see.. as you can tell i don't really no whats going on.. read and burn.. trail and error
    thanks
    ok..i really suck..
    I must have messed up the authoring part because it only authored one movie!!
    try again
    ok here is what i have..
    a mix of svcd and vcd.. i had it author but in only authored the first movie in the vts folder which came out great.. still wouldn't play in my stand alone = nero.. played fine in my pc
    I am running it again and adding another movie "daring"..
    this is my last chance to play around tonight since i'll be off to work but i will attempt to burn with something other than Nero!!
  11. Guest
    ok ran it again and it still only put one movie into the vts folder at 1.5
    here's my conversion............
    Starting (S)VCD2DVDMPG+: v1.0.1259.17369
    Begin time: 7:14:10 PM
    ******** Ripping SVCD images to get mpegs
    ############### New MPEG File ###############
    File: C:\TestArea\********.mpg
    Horizontal Res: 352
    Audio SampleRate: 44100
    ******** Demultipexing original mpg file
    ******** Resampling audio from 44.1 KHz to 48 KHz
    ******** Multipexing elementry streams
    --- Conversion details:
    Horizontal Res: 352
    Audio SampleRate: 48000
    Horizontal Res: 352
    File: C:\TestArea\***********.mpg
    Horizontal Res: 352
    File: C:\TestArea\****.mpg
    Horizontal Res: 480
    File: C:\TestArea\*****.mpg
    Horizontal Res: 480
    File: C:\TestArea\******.mpg
    Horizontal Res: 480
    Horizontal Res: 480
    File: C:\TestArea\*******.mpg
    Horizontal Res: 352
    Horizontal Res: 352
    Horizontal Res: 352
    File: C:\TestArea\*********.mpg
    Horizontal Res: 352
    ******** Creating DVD...
    Creating VTS
    ============ Complete ============
    ============ Duration: 00:54:45.7812500
    any thoughts would be apprectiated
    if i seperate the VTS tree and add 3 seperate nodes that would then create 3 vts folders right?? how would i then burn?
    thats me above
  13. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    The posible issue you have, looking at your log, is that you are mixing VCD & SVCD content. Not a problem but you must seperate the content into different VTSs. This would give you one VIDEO_TS folder containing your DVD which just so happens to contain 2 VTSs......
    ok so if i seperate the VTS tree and add 3 seperate nodes this should work ok!! i'll try it out when i get home in about an hour!!
    Again crissyboy great work, your support is apprectiated, shows you give a damn about your prog!! I will be sending a couple people your way.
    worked out perfectly thank you for your help!!!
    I love this program... I was able to put 2svcd's and 1 vcd on the same disk!!
    I also burned with nero as video dvd.. as they have resolved there issues with the standalone players
    Nero Burning Rom 5 5 10 35
    Crissyboy again thank you for painfully taking me through this!!
    congrats on a program that takes the pain out of this process!!
    goodnight!!
  16. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Pleasure. Don't forget to vote!
