Now that I have a player that will play SVCDs (and XSVCDs) I'd like to take the VCDs with the header trick I used for my Panasonic RV-32 player and convert them to a compliant MPEG2 file for use as a SVCD in a player that can play SVCDs. I've tried everything in TMPGenc , multiplexing, de-multiplexing etc I can think of and none of it works. Is there a guide anywhere that shows how to reverse the header trick so I can burn it as an SVCD? Tried ISObuster guide and still no go.
Thanks,
Tim
Results 1 to 1 of 1
Reversing PAL speedup.
By rcavanah in forum EditingReplies: 3Last Post: 22nd Sep 2011, 14:26 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 17:21 -
Reversing a fade to black
By dave_van_damme in forum EditingReplies: 10Last Post: 12th Mar 2009, 22:15 -
Reversing Clips - VideoStudio
By markannab in forum EditingReplies: 1Last Post: 15th May 2007, 22:35
