I downloaded an MPEG-2 file in PAL format. I can play it in Windows Media and the DivX Player just fine. But when I try to bring it into TMPGEnc to convert it, it gives me a "can not open, or unsupported error". If I try to open it in VirtualDub, it says "MPEG Import Filter: pack synchronization error".
If my computer has the codecs to play the file, why wouldn't it be able to open it for conversion??
Please HELP!!!
Keyz
Guest
I may be wrong but....
Do you have the mpeg2 pluggin for TMPGenc? And do you have the correct codec for mpeg2? I seem to recall the TMPGEnc needs a certain mpeg2 codec. Like the one with power DVD player. But as I said, I could be wrong.Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Can't convert files downloaded from a file hosting site
By ibzomie in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2010, 20:27 -
Which DVD Player For Under $50 Plays Most Downloaded File Types
By DJboutit in forum DVD & Blu-ray PlayersReplies: 10Last Post: 6th Jan 2010, 15:55 -
What Program will convert both DVD and Downloaded Movies ?
By JMGrande in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2009, 16:46 -
cannot convert downloaded file in xvid4psp
By suevee in forum Newbie / General discussionsReplies: 2Last Post: 4th Aug 2009, 19:55 -
I have downloaded file clips in .divx how can I convert to .avi?
By Ricksasha in forum Video ConversionReplies: 8Last Post: 13th Nov 2007, 14:36
