Can anyone tell me why I keep geting this error message when trying to convert an avi in tmpgenc.V2.513.53.162.
I have no idea what it is and why so If anyone has had this and fixed it could they let me know how to do it.Thanx![]()
First, make sure your AVI has no bad frames. Load it into Virtual Dub, select Video-->Scan video stream for errors, then get back to us.
Hello. -
Ok I tried that and no luck I have also tried diferrent films and it aint happening ggggrrrr.this message only ever poppes up when i go into the source range menu????????
And now i get this message (read error at address 00011EE3 of Module `TMPGEnc.exe`with 00000028.this was while trying a difeerent movie.is there something wrong with my tmpgenc?
i was getting the same problem, is the movie you're trying to encode xvid codec?
if so, i had to uninstall tmpgenc, reinstall, convert the movie to a different codec then worked fine, other people have had same problem (search the forums)... -
Just change the priorities as follows in your TMPGEnc->Options->Environmental Settings->VFAPI plug-in:
Directshow.....3
AVI2(OPEN DML).....1
BMP/PPM.......-2
DVD2AVI......-2
TMPGEnc Project.....-2
Rest of them set all on 0
I tryed this, it works!!! -
Reinsalling normally solves this one.
a disk error occurred during a write operation
By SE14man in forum ComputerReplies: 8Last Post: 8th Nov 2011, 01:16 -
TMPGEnc Write Error's of module 'P3Package.dll'
By manicradio in forum Video ConversionReplies: 0Last Post: 29th Dec 2010, 17:55 -
VirtualDubMod ntdll error.
By tat2jr1 in forum Video ConversionReplies: 10Last Post: 25th Jul 2009, 07:15 -
"An unhandled exception occurred in 3rd party module and will be close
By BLSAMPLES in forum ComputerReplies: 4Last Post: 12th Jul 2009, 22:30 -
Access violation in module ntdll.dll
By Blå_Mocka in forum AudioReplies: 3Last Post: 10th Feb 2008, 13:09
