I have a couple VOB files that i need to convert to MPEG to later burn on DVD what program will do that? Only reasion i want to convert them is because i can not find a program that will open .VOB files and let you edit them and add menus.
Virtual Dub will open VOB files, then you can frameserve to MPEG with TMPGEnc from there.
Hello. -
DVDlab will accept VOB files as part of its input to the DVD authoring process, then you can add your menus etc.
If that is not suitable for you, you could try de-multiplexing the mpeg elementary streams using TmpGenc, Mpeg tools simple de-multiplex option. These should the be accepted by most Authoring programs.
Hope this helps. -
Not that I would recommend them for general useage, but neoDVD (might require the plus version) imports VOB files. And Roxio DVD Creator 6 comes with DVD Builder which imports VOB files.
Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge. -
I have Roxio DVD Creator 6 it will open .VOB files but it always gives me an error.
Wouldn't it be better if i converted the .VOB files to MPEG-2 instead of AVI? MPEG-2 will take up less space right and the movie would not have to be re-encoded after i edit it before i can burn it on a DVD. -
Demux your VOBs with VOBEdit, import your M2V and AC3, MPA, or WAV into whichever DVD authoring program you like and add your menu. By demuxing you are not losing any quality, simply just spliting apart your VOB.
Faceman101 is there any guides on how to do that? I do have VOBEdit.
Thanks -
Originally Posted by David9799
https://www.videohelp.com/forum/userguides/120021.php
Tool to Convert Single File to Multiple Formats Simultaneously
By pabling19 in forum Video ConversionReplies: 1Last Post: 15th Mar 2011, 12:13 -
DVD Demuxer tool making 0kb .VOB files
By Madvillain in forum DVD RippingReplies: 5Last Post: 6th Jul 2009, 04:11 -
a good tool for joining dvd vob files (which make up one single video) to g
By extent in forum Newbie / General discussionsReplies: 20Last Post: 23rd Jan 2009, 13:00 -
large file split for multiple displays and convert ... what tool 2 use?
By rodpacker1 in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 03:03 -
How do i convert multiple VOB files at 1 time using PSP Video 9
By mac7654321 in forum Video ConversionReplies: 1Last Post: 22nd Sep 2007, 06:59
