In DVD-Lab, you are supposed to be able to resample SVCD audio to 48 kHz. I have done this before in DVD-Lab and it works fine, however, I now have a file that it won't resample. DVD-Lab is telling me that the file either doesn't exist, or that it is being used, neither of which is correct. Anyway..... here are my two questions:
1. Does anyone know what I'm doing wrong and how to fix it?
2. Or, does anyone know another audio program that will take a 44.1 kHz mpa file and resample it to a 48 kHz mpa file?
thanks,
papaholmz
BeSweet ought to be able to do that conversion for you.
"Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
192 vs 96 vs 48 vs 44.1 KHz?
By therock003 in forum AudioReplies: 22Last Post: 19th Nov 2012, 09:55 -
Is AAC 48.0 KHz good audio for a bluray rip?
By AndyD in forum Blu-ray RippingReplies: 3Last Post: 5th Jun 2010, 18:18 -
Is a 44.1 KHz audio capture OK for a compliant DVD?
By c627627 in forum Capturing and VCRReplies: 8Last Post: 23rd Mar 2010, 04:29 -
capture of S-Video and PCM 44.1 kHz at the same time ?
By nidi in forum Capturing and VCRReplies: 16Last Post: 23rd Apr 2008, 14:16 -
24/96 khz
By mikee55 in forum AudioReplies: 3Last Post: 10th May 2007, 10:39
