Hi Folks
I've the latest "+" version and the new menues still are not available in the list (the menu button is still greyed out) i did copy the folders directly from the zip file to the svcd2dvd+ dir as instructed but to no avail. Also since upgrading to the lastest release strange things are now happening - i loaded a few svcd files into the "machine" and sorted the vts etc - let the prog do it's thing and got the "complete" message in the log file - i went to look for the newly created vob file and guess what - none to be found - the new dir is there but nothing else - wasted another few hours trying again with all the files in one vts - same thing?
Odd.. Also why is the prog not converting a 480x480 file ready to be used? I thought it was supposed to or maybe i'm just mistaken?
Excellent piece of software in the past but maybe this is just a glitch with my setup?
Anyone else having a prob?
Josh.![]()
Menu button becomes ungreyed when there are two VTSs. There is no point having menus for 1 VTSs and as this is just a proof of concept at the moment menus are only available for 2 VTSs maximum.
Does this happen for all your svcds or just one in particular?i went to look for the newly created vob file and guess what - none to be found
Not sure what you mean.. Could you clarify?Also why is the prog not converting a 480x480 file ready to be used? I thought it was supposed to or maybe i'm just mistaken?
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I have same prob, film is italian job centropy (bin/cues etc)....video_ts folder there but empty. found if i ripped mpgs out with isobuster first it completes ok...back to using the free version with maestro, but it was the whole idea of a one touch solution why i upgraded...If anyone knows the prob, let us know
I will investigate.
OK having error problems, after I press "menu"
This error occurs the first time I press "menu", and then every time data is put into menu area eg when I put in the name of first movie, the error box pops up again. Same for second movie title. Similar error box on all occasions. BTW the 2 badgers sample menus do come up
I get a error window which says" An unhandled exception has occurred in your application. If you click continue, the application will ignore this error and attempt to continue. If you quit, the application will be shut down immediately"
"Invalid parameter used"
When I try to exit menu area, this part of the message changes to "Object reference not set to an instance of the object"
I have to close the menu box and it doesnt seem to actually create a menu
A "Details" gives the following info:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: Invalid parameter used.
at System.Drawing.Bitmap..ctor(String filename)
at d.g(Object A_0, EventArgs A_1)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVDMPG+
Assembly Version: 1.0.1259.17369
Win32 Version: 1.0.1259.17369
CodeBase: file:///E:/SVCD2DVDMPG+/SVCD2DVDMPG+.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
RegistrationSDK
Assembly Version: 1.0.1218.19534
Win32 Version: 1.0.1218.19534
CodeBase: file:///E:/SVCD2DVDMPG+/RegistrationSDK.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
System.Security
CodeBase: file:///c:/windows/assembly/gac/system.security/1.0.5000.0__b03f5f7f11d50a3a/system.security.dll
hzgd5ivz
Assembly Version: 0.0.0.0
Xceed.FileSystem
Assembly Version: 1.0.29.0
Win32 Version: 1.0.29.0
CodeBase: file:///E:/SVCD2DVDMPG+/Xceed.FileSystem.DLL
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
MagicLibrary
Assembly Version: 1.7.3.0
Win32 Version: 1.7.3.0
CodeBase: file:///E:/SVCD2DVDMPG+/MagicLibrary.DLL
FolderBrowser
Win32 Version: 0.0.0.0
CodeBase: file:///E:/SVCD2DVDMPG+/FolderBrowser.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog. -
Josh4U - A bug has been fixed in the latest release which may resolve your empty dvd folders. Please update/test & confirm.
Creating Menus on avi files
By zammil in forum Authoring (DVD)Replies: 1Last Post: 15th Oct 2010, 14:27 -
How to add menus to avcHD without re-encode the files.
By riky in forum User guidesReplies: 0Last Post: 22nd Aug 2010, 02:07 -
SolveigMM Video Splitter 2.2 Release. Files joining added
By DmitryV in forum Latest Video NewsReplies: 0Last Post: 20th Apr 2010, 09:13 -
problem with menus when burning VIDEO_TS files to DVD
By samd292 in forum MacReplies: 3Last Post: 24th Jun 2008, 09:49 -
Help needed with Avi2dvd "hiccup" (muxed mpeg2 avail but didn't f
By bgart13 in forum Video ConversionReplies: 2Last Post: 17th Apr 2008, 18:54
