My first post.
I am wanting to puchase a Hard Disk Recorder (as most of us do). I would like to purchase the Pioneer.....but....there is an issue from all of the releases that I can see. I really want to have the timeslip functionality that Panasonic provides. The Pioneer states that you can record onto the DVD whilst playing from the hard disk or vice versa, but not using the same medium. The Panasonic seems to be able to do this though.
If I have recorded some TV show, I do not really want to keep it once I have watched it.
Does anyone know if the Pioneer will support the Timeslip functionality?
Thanks in advance.
According to the specs listed at (which are the best I can find for now, and hopefully they are correct):
http://www.1-877camcorder.com/dvr002h.html
Yes, the Pioneer will simultaneously record and play on DVD-RW discs if they are certified at 2x speed or better.
Another great feature of the Pioneer machines which isn't available on any other brand of standalone is the ability to use the firewire in both directions - in and OUT. -
Thanks for your help piano632.
Hopefully they will expand the functionality to be like the Panasonic's timeslip.
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 05:38 -
Hard Disk Replacement on Pioneer DVR-433H
By linkox in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Jun 2008, 18:21 -
Pioneer DVR-920HS ... help !! (Hard Disk)
By indio76 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 4th Feb 2008, 06:17 -
Pioneer and Panasonic DVD Recorders w/HD?
By MCnDaHouse in forum DVD & Blu-ray RecordersReplies: 15Last Post: 16th Dec 2007, 01:48 -
New Panasonic Recorders with Hard Drive?
By duffy76 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 15th Jul 2007, 11:51
