i used to have no problem burning my mpg files to vcd now i am lucky if i can get one made always give error failed i tried reinstalling but does the same thing sometimes it gives me an error of SCSI timedout or other eroors tried changing the options still ends up the same way can anyone help
No clue whats wrong hopefully someone else can help. But I can tell you want you need to do after you get everything working again.
This is how I can FIX ANY SOFTWARE PROBLEM IN LESS THAN 8 MINUTES.
1) When everything on your system is runing at 100% backup your system partion with Norton Ghost 2003. You can store the image on another partion (such as D
or burn it to CD/DVD RW.
You can use other programs, but they have to be able to do a complete image of your partion from outside of windows (ie DOS). System Restore cannot backup system files that are in use and neither can any program that runs within Windows.
2) Keep as many of your personaly files and folders on a partion different from where windows and all your other programs are installed.
I keep "my documents", desktop and email store folder on my D: drive
3) When you have a software problem you quickly move any important files to your D: drive.
I have to manually move my address book, favorites folder and any saved games.
4) Restart your computer with a ghost floopy and restore your os partion from the backup image.
I have a pretty fast machine, so I can be in a irc channel talking to a friend, leave the channel, completely restore my pc and be back talking within 8 min.
5) Sometimes the problem persists. Since the backup has restored you software to exactly the way it was when everything was working fine then you know that the problem is due to hardware and not software.
Problems burning AVCHD w/Nero & IMGBurn...
By girlcreeture in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2011, 11:31 -
problems burning with nero and imgburn-pixlation and long burn
By pokitisme in forum Software PlayingReplies: 5Last Post: 2nd Sep 2009, 03:12 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 16:56 -
USING Nero TO SOLVE ALL BURNING PROBLEMS?
By guitarparth in forum Newbie / General discussionsReplies: 8Last Post: 16th Nov 2007, 19:18 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 16:36
