I encoded an XVID (23.976 FPS)avi film too CBRMpeg -1 layer2 useing TMPGenc, to be burned to dvd. The ending result is the picture slightly pauses every few minutes! And it drives me absolutley nuts!
My Settings were:
Non interlace,
4:3 525 ntsc aspect ratio
Video source was film movie
Inverse telecine was checked
Does anyone know what i did wrong, to make this happen!
It seems to happen with movies i convert useing TMPGEnc, so i assume it must be the way i am setting it to encode..
If someone can give me a little guidance, i would great ly appreciate it
Thanks!
what did you play it on????
What did you burn it onto???
Was it some standard you kept yourself to ?? ( perhaps vcd?)
More details would help solve the problemAnyone tired of his old DVD burner? Why put it into the trash? Contact me! :)))) -
I played it on my home dvd player....RCA, also played it on my PC with power DVD, and both showed the same problem!
I authored with ULead, and Burned it too DVD+R useing Nero.
Thanks -
I have had the exact same problems with a Ulead encoded divx conversion, burned with both the Ulead software, and Nero.
I'm going to try to take that mpg file and see if I can author it with something else... Hopefully it'll fix the glitches.
I am going to bet that the pauses come with a slowness in the video for a half second or so after the pause, correct? Mine also has a brief pop or drop out of audio at the same place..
Some burns do it every few minutes, some every 10 or so minutes..
Just for info: I used my TDK 420 burner, Memorex & Fuji DVD+R's. Played on a Apex 1500 & a Sony S300, as well as my in PC dvd reader. -
Are you sure in what you are doing???Originally Posted by tpw115
perhaps read this :http://www.lukesvideo.com/
read about inverse telecining
also try to read a bit about video standards here at vcdhelpAnyone tired of his old DVD burner? Why put it into the trash? Contact me! :))))
Player pauses
By Daijard in forum Software PlayingReplies: 8Last Post: 9th Feb 2010, 21:53 -
how to record without pauses
By mehrlicht in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Apr 2009, 17:00 -
Ripping a film that includes subtitles but only briefly
By sorethumbs in forum DVD RippingReplies: 10Last Post: 15th Jul 2008, 09:44 -
divx pauses during playback
By poppinjay in forum Newbie / General discussionsReplies: 6Last Post: 8th Oct 2007, 20:41 -
Video backups contain pauses
By dadbackup in forum DVD RippingReplies: 10Last Post: 15th May 2007, 16:13
