i just purchased the full copy of this great program and i find it to be great except for the fact that, whenever i burn the vob files that are created with nero, i can never get my menu, that i created, i though when i burnt it that it will come out with menus and all, is it how in burning it, is it how im authoring it, is it my dvd player...i own an apex ad 1200...holla back
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"? -
SIRCOOKS, when you are in the create menu screen make sure the the Firstplay action box has "Display main menu". I use TMPG DVD and like it a lot. It is fast and easy to use.
I also have problems with menus. I can get the main menu on screen, with "Play" and "Chapter" selections. "Play" works fine. "Chapters" brings up the next menu with only the first chapter. What am I doing wrong, or failing to do?
Yorel, after you add a track click on edit, then click add, now you can have TMPG create chapters by timecode, time interval or number of chapters.
I must have a mental block (the alzheimer's is a given, but that's beside the point, like my ears). I did not see any reference to that in the help.
Thanks a bunch. -
nac, I don't know if there are other templates but you can change the background image by clicking edit when you are in the create menu screen. I created a folder with images from DVDit, MyDVD and DVDlab to
give me more background image options.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
TMPGEnc DVD author.
By netbuddy in forum Authoring (DVD)Replies: 20Last Post: 24th Aug 2007, 03:27
