I am trying to capture from a 25 fps PAL VHS source (from camcorder, not film) to
SVCD but I get crappy results. I use the following method:
1. Capture to AVI with huffyuv in 640x480 with the hauppage
tv tuner card (yes it can be done!)
2. Convert to SVCD with TMPGEnc, using standard SVCD setting
and interlace encoding with field order : bottom field first (field B), motion search precision set to highest quality
3. Burn to SVCD with VCDimager or nero.
Now the problem is when I play the discs in my standalone DVD player the picture is kinda shaky. Not as shaky if as if you choose the wrong field order, but it's still very irritating!
If anyone has any ideas why please let me know
thanx
You should either capture all of the lines(576) or half of them(288). Anything in between will definitely cause problems.
<font size=-1>[ This Message was edited by: RemoteCtrl on 2001-09-24 15:49:35 ]</font> -
well, the first thing that you're doing wrong is that you're trying to make a svcd out of a vhs.. it doesn't matter how many filters you apply, the result will be the same as if you captured to vcd format. capturing to vcd will also eliminate your problem of interlacing since a vcd stream is only 1/2 resolution and records only one field. however, if you insist on capping to svcd, then my only comments would be to capture at proper PAL svcd resolution, make sure that your max. bitrate does not peak above what your standalone can handle, and to make sure that your standalone can play the cd-r's you're using.
What am i doing wrong (VHS Restoration)
By Asesinato in forum RestorationReplies: 50Last Post: 14th Apr 2012, 07:02 -
Done capturing my VHS, what now?
By Akerhage in forum Video ConversionReplies: 31Last Post: 27th Jul 2011, 09:37 -
capturing from VHS
By halbblah in forum RestorationReplies: 4Last Post: 1st Nov 2009, 17:35 -
Capturing VHS using All In Wonder HD
By ukcolonelcolin in forum Capturing and VCRReplies: 14Last Post: 2nd Dec 2008, 10:32 -
Need advice about capturing VHS
By jimlong in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2008, 03:11
