I have some MST3K Divx episodes that I'm converting to DVD for my nephew. I've burned them succesfully to where they play in my Panasonic a05, but they won't play on my standalone player. The compatibility matrix here says my KLH-221 should read DVD-R/W, but neither Princo DVD-R's nor Memorex DVD-RW's work.
My question is whether my procedure is correct:
I first extract the audio w/ virdualdub. I then use TMPGEnc to encode to .mpg with the Divx .avi and the extracted .wav. Then I use Spruceup to create the .vob's, and burn with Nero.
Are there any tweaks to making a DVD "more compatible" with standalone players?
Thanks.
I had the same exact problem, and it might seem rather simple. Maybe it will work for you, maybe it won't.
But when I put my DVD into the DVD player it wouldn't start playing automatically (authored and burned same way as you) but pressing play on the remote made it run. Give it a try! -
Yeah that happens when you dont set a "first play" in your dvd. I get that a few times when i forget to set it.
Is "first play" a SpruceUp setting, or a Nero/other-burner-sfw setting?Originally Posted by DVDJunkee
I'm out of town right now, but I plan to try your suggestion when I get back . I'll let you know how it goes.Originally Posted by jarvis1781
Thanks!
Set-top Blu-ray player that can play IFO
By AndyRough in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Sep 2011, 05:35 -
Looking for compact set-top DVD player
By Djinn987 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Jun 2010, 15:20 -
PC drive in set top DVD player?
By wetcamelfood in forum Newbie / General discussionsReplies: 4Last Post: 18th Aug 2009, 14:59 -
AC3 sound - worked in software, didn't on set-top player
By dadrab in forum Authoring (DVD)Replies: 12Last Post: 25th Feb 2008, 08:15 -
portable media center in addition to set-top player?
By celchlepp in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 12:30
