Results 1 to 9 of 9
  1. hi all,
    I have a load of vcds i recently aquired. I put them in my standalone dvd player and they are all reading as mp3 discs and not playing. When i checked them on the computer they ARE vcds and play using interwin no probs?
    My dvd standalone accepts vcd, xvcd, so i dont understand why there not playing or recognising.
    They are not svcds either!
    Any ideas anyone???
    Apr 2002
    The State of Frustration
    Has your DVD player ever accepted your homemade VCDs, and if not, does your player play CD-Rs (not MP3s)?
    Hello.
  3. yea my player has accepted all my vcds i have made, including kvcds, svcds with a header trick, all types!!
    Apr 2002
    Does your player recently been having trouble accepting any other media or formats, and when was the last time you had it cleaned?
    Hello.
  5. its played everything before and plays everything else now fine and its only about 6 months old
    Apr 2002
    What is your DVD player?
    Hello.
  7. bush 2020
    ive just checked the vcds that wont play and they are just standard vcd format
  8. firmware update so the bush 2020 can play svcd's with sound.Use the link below to download the file unzip files and burn to a cdr.Put the cdr into your 2020 and it will update the firmware.On the page its self it dosn't say anything about the 2020 but its all to do with the chips used in the 2020.I'v just used this my self and it works great i'm now playing svd's.It took me a long time to find this so enjoy my hard work.
    http://www.powerglitch.com/update.html
    STCineMaster - Build 3.388 - Vestel:3.08b10
    Driver 4.1, Build 706
  9. I dont have that DVD player, but thats so cool. I wonder if mine can do that firmware update.
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
