How do i record a regular video clip in slow motion speed??
The easy way is to capture it normally, then have an AviSynth script encode it in slow motion.
Hello. -
you could try cranking up your frame rate of your capture up, then play it at a normal frame rate.
If your source is 30 frames per second, then 60 frames per second would be half speed and 90 frames per second would be 1/3 speed (when played back at 30fps)
but really, since the source is 30fps, you'd just be doubling (or tripling) every frame, not really slowing it down. You might be better off with something like Realviz Retimer that makes new in-between frames for something like this. Expensive solution, though.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
smooth slow motion
By nitrobaorder in forum EditingReplies: 22Last Post: 18th Oct 2010, 06:19 -
Slow motion with ffmpeg?
By charlesdavison in forum ffmpegX general discussionReplies: 2Last Post: 31st Aug 2010, 09:07 -
Slow Motion Effect
By leedownen in forum Video ConversionReplies: 5Last Post: 13th Feb 2008, 01:16 -
Slow motion
By Pliny in forum MacReplies: 7Last Post: 7th Aug 2007, 00:02 -
Slow Motion
By sbuckmybballs in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2007, 02:16
